- First Name
- Teja
- Last Name
- M
- Member #
29385
- Ham/GMRS Callsign
- KN6OOX
Hi,
Selling my triple locked 1999 Lexus LX470 - 183K miles and details are below
Powertrain -
Service below done @171K miles - 8/3/21
Throttle body replaced
Air snorkel along with K&N filter
Borla Cat-back exhaust @165K
Drivetrain -
Rack and Pinion replaced
EATON front e-locker @167K
Rear Lexus Axle swapped with Landcruiser axle with Factory e-locker. Along with factory harness and computer module @167K so works like a OEM
Transfer case fluild flushed and replaced @167K
Front/Rear diffs flushed and replaced @167K
ARB diff breather extenders
DBA performance Rotors and Brake Pads all around (Less than 3K miles)
Front wheel bearings and seals replaced when rotors are replaced
Rear Calipers replaced
Brake fluids flushed and replaced
Suspension/Wheels/Tires -
Dobinsons IMS shocks front/rear - 2" lift
Dobinsons Medium duty springs - 2" lift
OME Torsion Bars
Dobinsons UCA’s
Dobinsons Diff drop kit
Spring coils insulators to avoid metal to metal contact
NO AHC system. AHC fluid Reservoir and lines in the engine bay are removed to make room for AUX battery
Method 701 - 17" (including spare) - Less than 200 miles (Installed on 12/1/21)
BFgoodrich K02 285/70/R17 - almost new
I have Tundra 18" steel powdered coated to white that I can include in sale if you want
Ironman 4x4 Lower control arm reinforcing brackets in the box
Bumpit Offroad bump stops in front and Timbren bump stops in rear
Interior/ Exterior/ Accessories -
ARB front bumper
ARB LED fog lights
ARB Solis Spots W/ Amber Lens cover (Have clear one's as well)
WARN 10-S winch
Ironman Front recovery points
ARB 8'x8' awing with integrated adjustable LED light
4 x Gamaviti Multi brakets to mount Awing and Shower room awing
Renogy 100w Solar panel mounted on tilting brakets
Kaymar rear tire carrier W/ Jerry can holder
Pioneer 1500NEX Apple CarPlay/Andriod auto Head unit
Head unit USB connection flush mounted on console that has extra opening for rocker switch (Using Ben3Dbuild solution)
Scan Gauge II mounted in Homelink location (Using Ben3Dbuild solution)
Ram ball mounted replacing the blank insert (Using Ben3Dbuild solution)
Angled mount next to Ram ball mount (Wanted to use it for HAM unit)
Have Metaltect 4X4 ditch light mounting bracket in Box (Only driver side - wanted to mount HAM antenna)
Midland CB radio and Antenna mounted on Front bumper
2x AUX USB ports installed near shifter
Center console organizer from Ben3Dbuild
I also have 2nd row 12V and extra USB outlets and panel that replaces blank dummy from Ben3Dbuild that needs to installed (Usually a climate control in fully loaded models)
2nd row 40th split deleted and mounted brackets from trail tailor hold base for my fridge
12V, USB and Anderson charging outlets installed in rear cargo
Weather-tech mats (front and 2nd row)
JL audio speakers all around and twitters, JL audio amp, heavy duty wire routed to power outlets (mentioned in post) in rear cargo area
LCP mud flap eliminators in box
Drawer system build from 3/4" Birch plywood (staine/sealed and top platform is covered with carpet) and 500lbs payload sliders (I know its overkill) and also the top platform converts to a sleeping platform
I have all the service records since the day I owned and original owners manual as well in Lexus leather case. I never trusted some random shops with my cruiser so always maintained at Mudrak Custom Cruisers and Top Shop Auto even though they are very long drive from my house. I'm 5th owner. Ever since I bought the back in Jan 2021, I never skimmed on maintenance or using quality parts. Always ran on 91 octane and Modil 1 full synthetic oil since the day I owned. Even the previous (1-3) owners serviced the vehicle most of the times in dealership and 4th owner barely drove it for a year as you can in Carfax
Interior - 7.5/10, regular wear on front seats for 22yr vehicle. 2nd row seats are Ok but I never used them except to store camping/trip stuff
Exterior - 7/10, Few rock chips on hood and pin stripes. Small dent on passenger rear fender (Will try to get it fixed before selling)
Happy to answer any questions re LX470
Asking $25,000 OBO
Powertrain -
- Timing belt replaced
- Oil and filter changed
- Thermostat housing/gasket replaced
- Radiator hose(s) and T-fittings replaced
- Serpentine belt replaced
- Water pump replaced
- Thermostat replaced
Drivetrain -
OME Torsion Bars
Dobinsons UCA’s
ARB front bumper
ARB LED fog lights
WARN 10-S winch
Asking $25,000 OBO
