- First Name
- Gary
- Last Name
- Luokkanen
- Member #
41051
Influencer III
19540
Explorer II
They also make a 12v powered battery eliminator. That way, you don't need to worry about the battery at all.I have three of theBAOFENG five VR and absolutely love them the magnet mount and adapter significantly increase the range to 5 to 8 miles. We typically use them when we’re In a convoy traveling . my only complaint is the battery life is not up for a full day of chatter. But they make a auxiliary battery has a USB charge port in the side of it so you can plug it in while you’re out on the road.
The program software is super easy to use. You can download all the channels from the existing ham radio databases that will also include the offsets for hitting the repeaters in your area. I use mine is ham and GMRS and FRS as well as NOAA and my local sheriff police fire and first aid stations that are listen only.
Use radio reference logging in is free it will let you search by region and type
RadioReference.com - Scanner Frequencies and Radio Frequency Reference Database
www.radioreference.com
I would forget and go to take it out and spot someone only to be talking into a radio with no power ;)They also make a 12v powered battery eliminator. That way, you don't need to worry about the battery at all.I have three of theBAOFENG five VR and absolutely love them the magnet mount and adapter significantly increase the range to 5 to 8 miles. We typically use them when we’re In a convoy traveling . my only complaint is the battery life is not up for a full day of chatter. But they make a auxiliary battery has a USB charge port in the side of it so you can plug it in while you’re out on the road.
Haha. That's fair! It's always good to have a separate spotting radio as well. I keep my baofend clipped to a pocket on the side of the front passenger seat in the Xterra. If I need to hand it to someone to spot, it's right there.I would forget and go to take it out and spot someone only to be talking into a radio with no power ;)
To translate, the authorities don't like the fact that you can program the radio to operate outside the legal bands.In Germany/Europe, the Federal Network Agency has recently prohibited to continue to distribute, make available, place on the market and pass on of several BAOFENG devices, including the UV-5R 5W HT. The given reason is that it was determined that the affected devices do not comply with the requirements of the Radio Equipment Act (FuAG), the declaration of conformity is incorrect and laboratory measurements / investigations have shown that various EU directives are not met. If I remember correctly, one of the issues was the transmission in addition to the permissible bandwidth.
I encourage you to check out the Communications section of OB for more info on GMRS and ham radio should you decide to venture down that road.Thanks People! Really appreciate it!
Gotta do the homework before jumping in!
Explorer II
