HI All from Long Island.
I recently did a trip through the NJ Pine Barrens. Along the way we needed to check a noise coming from my sons 2017 Tundra. Luckily we were on pavement so broke out the bottle jack that came with the vehicle only to find out it would not extend high enough to lift the back of the truck. No problem I had a 12 ton bottle jack brand new (blackjack I believe was the brand). That was completely DOA. Would not even extend a little bit after 15 minutes of priming with the handle. Fall back now is on my 2016 4runner OEM bottle jack. Would jack up but did not have any lift capability when encountering resistance on either vehicle. Triple failure!! None of the OEM jacks were ever used nor the Blackjack. No fluid leaks, just non functional (yes we pumped the handle on all of them 100's of times to no avail). Hence my inquiry if anyone has any input, suggestions, or tips as I am looking at an air bag jack. I was considering the one from Vevor (link below). We wheel mostly on sand living on LI. We don't do any crazy trails or rock crawling. Mostly easy novice stuff.
My concern with the air bags jacks that run off the exhaust is, does it cause problems with sensors being you are restricting exhaust flow?
Any thought or comments are very much appreciated.
VEVOR 4 Ton Exhaust Air Jack 8800LBS Capacity Inflatable Air Jack Off-Road Exhaust Air Jack Lifting with Bag for Vehicle Car Truck | VEVOR US
Discover VEVOR 4 Ton Exhaust Air Jack 8800LBS Capacity Inflatable Air Jack Off-Road Exhaust Air Jack Lifting with Bag for Vehicle Car Truck, High Lifting Capacity and Premium Material at lowest price, 2days delivery, 30days returns.
www.vevor.com
