![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/ncreator2.png)
Creator II
Traversing a vast majority of the Swell and surrounding areas over a full 7 days. TRIP IS FULL.
Creator II
Trail Blazer III
27816
Man this looks fun, but we're taking a two-week trip in June and I'm not sure we could swing this much additional time off!
Creator II
Hey TJ,Hey @Dave Purvis I'm interested in joining you for the trip, but want to make sure my rig is suitable:
It's a 2011 Silverado 2500HD (Duramax/Allison) with a solid front axle conversion (WFO radius-arm kit with a '05+ Super Duty Dana 60 and Fox coil overs), 37x13.5" M/Ts, 4.56s, ARBs front and rear, and by the spring my bumper/winch will be on. As you can see I have a Four Wheel Camper Hawk in the back. I do carry a full size spare, a jack suitable for this tank, tools, etc. Additionally the rig has a 60 gallon fuel tank, and even in 4LO aired down I see 10-12 MPG so my fuel range is at least 600 miles of slow, technical work. The rig is very capable, and I grew up wheeling so I'm reasonably competent. That said, it's big and heavy so I want to be sure it won't be a liability for the group.
Thanks,
TJ
Thanks for the response Dave! FWIW the pic above was on White Rim trail at Moab. I imagine you've run it, just as a gauge I didn't find anything on it challenging nor did the truck. I'll research the trails on this trip more but it sounds like we should be good. As far as camping spots, I don't mind if I don't get the premium view... it's just a good excuse to hike around a bit. ;)Hey TJ,
Thanks for reaching out and sending details about your rig. It certainly looks and sounds like you are well equipped for this trip!! There will likely be some spots where a full size will be challenged. This is our first trip through the region ourselves, so I can't be too certain about when nor where we will hit those challenges, but from the trail reviews and videos I've seen, there will be a few spots. We are purposefully skipping Devil's Racetrack, which is the most technical and narrow trail in the area, so that is good.
One additional consideration is the group size. Many of the scouted campsites will be small(er) and we'll be fighting over who gets the best views! :) We may just have to split up in a couple places if it's too tight. We will be pushing it with 8-10 trucks, but I am hopeful it wont be a big issue and we are all okay with snuggling up a bit.
Based on what you've shared, I'm willing to take on the challenge if you are. The rest of the group will be local to the RM region, and part of an active OB group here, so it will be good to have some new blood coming along.
Thanks,
Dave
Creator II
Sounds good TJ.Thanks for the response Dave! FWIW the pic above was on White Rim trail at Moab. I imagine you\'ve run it, just as a gauge I didn\'t find anything on it challenging nor did the truck. I\'ll research the trails on this trip more but it sounds like we should be good. As far as camping spots, I don\'t mind if I don\'t get the premium view... it\'s just a good excuse to hike around a bit. ;)Hey TJ,
Thanks for reaching out and sending details about your rig. It certainly looks and sounds like you are well equipped for this trip!! There will likely be some spots where a full size will be challenged. This is our first trip through the region ourselves, so I can\'t be too certain about when nor where we will hit those challenges, but from the trail reviews and videos I\'ve seen, there will be a few spots. We are purposefully skipping Devil\'s Racetrack, which is the most technical and narrow trail in the area, so that is good.
One additional consideration is the group size. Many of the scouted campsites will be small(er) and we\'ll be fighting over who gets the best views! :) We may just have to split up in a couple places if it\'s too tight. We will be pushing it with 8-10 trucks, but I am hopeful it wont be a big issue and we are all okay with snuggling up a bit.
Based on what you\'ve shared, I\'m willing to take on the challenge if you are. The rest of the group will be local to the RM region, and part of an active OB group here, so it will be good to have some new blood coming along.
Thanks,
Dave
-TJ
Steward I
Creator II
Creator II
