35 vs 33's
ChilaMan
El Paso, TX 79935, USA
Ivan
FEs
DoD
Good morning. Looking for guidance here. So I have F150 w 4" lift and 35's. Its time for new tires. I'm debating going to 33's for sake of reliability and performance. Whats consensus on this? Thanks in advance and God Bless!!!
loper
Nampa, Idaho
Carl
Hendricks
33s will lower your effective gear ratio (more power).
33s are nicer to drive, on pavement.
33s will give you a lower unsprung weight. Lower unsprung weight is A: better for handling, and B: easier on suspension components.
33s cost less (a little).
35s raise the axles (ground clearance).
35s go over obstacles a little easier.
35s might have a higher load rating.
I've used 33s on a Ramcharger and an F250, and I was perfectly happy.
I have 35s on my van, but it's kind of over the top anyway.
For an F150 and 4" lift, I'd say 33s were best.
ChilaMan
Ivan
FEs
DoD
I do appreciate input!!!!
WTSMatt
Monterey, CA, USA
Matt
Stoddard
KN6TZY
Fire
I have 35's on my F150 and was debating them same thing. I've chosen to stay with 35's as they work better of off-road in my experience. Just, FYI, a 35 WILL for the spare under the truck on stock wheel.
Reactions: ChilaMan
SWLands
Oakland CA
Stephen
Williams
KN6QBJ
I am also a newbie, and I drive a 4Runner.
However I thought this YouTube from Australia was really helpful. What leaps off the page is the stopping distance on the highway is MUCH greater with 35" tires, and road handling is much worse. Plus they need regearing on my 4Runner = $$$. I have BFG KO2 33" tires and while I do a lot of off road, I also do a lot of highway. Plus it seems 33" will get me most places 35" will go - probably all I really need.
Billiebob
earth
Bill
Skinny 33s definitely. Like 33/10.50s
Better ride, increase yer gas mileage and range. Better acceleration AND braking, even if you regear, lighter tires spool up faster.... and spool down faster too.
Bigger tires only offer better floatation, if you need floatation you need bigger tires, maybe also lighter tires. If you aren't running thru the dunes you likely don't want floatation. On hard ground skinnier footprints will ride and track better. And lighter tires will ride and handle better. Floatation can be a factor on hard ground if you are crawling up a waterfall and aired down. Over irregular surfaces like rock ledges bigger and aired down is an advantage when properly geared.
Speed is another factor. The faster you are going the smaller, lighter, skinnier a tire you want. Thru standing water, slush, mud a skinny tire will track far better. A fat tire, regardless of diameter will be pulled sideways thru puddles and slush. Crawling you won't feel a difference but highway or forestry roads at speed. a wide tire can kill your confidence.
Tire choice is being honest about where you drive.
Plus $$$$$ why spend more than you have too. The choices are mind boggling once you ignore the crowd.
MOAK
Donald
Diehl
WRPN 506
Good vid from our friends in OZ. Another consideration, a big one, is how available a tire size is. I prefer tall and narrow - 255/85/16, however, good luck finding that size tire readily available in any remote town or fuel stop. So, I compromise and use 285/75/16, a little too wide for my taste, but stocked at most any tire shop in North America
Reactions: loper and Jim SoG
Jim SoG
Forums Manager
Educator I
10,890
Reno, Nevada, United States
Bro
USAF DAV
Moak you nailed a VERY important consideration. While going from Reno to Vegas via trails and mining camps got flat, spare was in worse shape than I remember, played hell finding my size tire...........
Jim SoG
Forums Manager
Educator I
10,890
Bro
USAF DAV
I think 35's over 33"s as long as new gears are no needed. Tires are the only way to raise the diff off the ground and every inch counts and that 1" will help. Performance is same unless motor small or weak and again the average weight diff should be ok. Now 33's to 37's are a whole different game and research NEEDS to be done.
Now you need to consider what type wheeling you do and how often, if it is a daily driver taken out once in awhile, go 33's, if it is off-road often, 25's IMO.
