So I just replaced the struts and shock all around with Bilstein 5100's. I ended up re-using my original coil springs that have 155k on them. I initially set the front struts to the fourth and highest setting which would raise the front 1.77" from stock. After having a tough time getting the lower mount onto the LCA I decided to move the spring to the third setting which would raise it 1.1" until i order some Dirt King UCA's. It seemed my limit was reached with the stock UCA's. I measured the height of the front from the fender to the center of the hub and found that one side is about 1/2" higher than the other???? Does anyone have any ideas what may cause this? I'm guessing maybe a weak coils spring. I am planning on replacing the springs with new ones in the next week or so.
Appreciate it any input.
