So I am starting down the road of tearing down a 1962 Willys Truck to build an overland truck. I am keeping everything stock save three things: suspension & tires, adding an overdrive and disc brakes. The goal is to restore it back to flatbed with removable sides, and eventually I want to build a camper to slide on and off the flat bed.
I don't plan on doing true off roading with it, but want it to be capable of handling unkempt dirt roads and easy trails. I have no intention of taking it rock crawling or fording anything past a shallow creek. On the tires I would like to go up to 31x10.5's to get width more than anything. I wouldn't mind lifting it 1-2 more inches on YJ springs to better the ride. Overdrive will help with road speed and allow me to split gears if need be to better handle hills. Disc brakes on the front axle are strictly for safety since road speed will be much faster with the overdrive.
Any thoughts on what else I should think of? Didn't know if a steering dampener would be worth it for mechanical steering, things like that. Any insight would be a ton of help! I hope to put some drawings up in a day or two of what the finished product will look like.
